Different CSV import directory config settings for different sites
yeh
Post by yeh » 27 Jul 2022, 14:44
Hi
Is it possible to have different config settings per site?
I am using multisite and would like to have different CSV import directories per site. Is this something that can be done?
Re: Different CSV import directory config settings for different sites
Post by aimeos » 27 Jul 2022, 14:53
Yes, you can add the site-specific configuration as key/value pair in the config table for each site in the Locale > Sites panel
yeh
Post by yeh » 27 Jul 2022, 15:05
That's exactly what I need. Thank you
