after submit the review , message is not showing
- VirtualSpy
- Advanced
Laravel version 9.22.1 , Aimeos version 2022.07.2 and PHP version 8.1.3 (Win)
what is the problem in this code and why is message not showing ....please help me to fix this
- p2.png (121.05 KiB) Viewed 6620 times
- p1.png (234.66 KiB) Viewed 6620 times
Re: after submit the review , message is not showing
The reviews are set to status "review" by default after submitting and must be set to "enabled" in the admin backend first before they will show up.
- VirtualSpy
- Advanced
review status is working....but i am getting problem in when submit the the review from profile there should show a message " Thanks for the review " that is not working
- VirtualSpy
- Advanced
Aimeos, will you answer ? Thanks
- VirtualSpy
- Advanced
I am talking about this message......this is not showing in mine..... please help me to fix this
- Screenshot_2022-08-01-07-08-16-964_com.android.chrome.jpg (253.59 KiB) Viewed 6556 times
- VirtualSpy
- Advanced
The problem has been fixed in this commit and will be part of the next 2022.07.x release:
https://github.com/aimeos/ai-client-htm ... d089470532
