Sitemap Job is not working correctly
Dennee
Post by Dennee » 02 Aug 2022, 06:52
I have two problems with generating sitemaps for aimeos in typo3.
1. The sitemap urls are wrong. I use aimeos in a subdirectory /products and all of the urls are build from the root directory
2. The sitemaps are compressed in .gz . That way I cant use them. Is there an option to unzip them?
Hopefully someone can provide me with the missing configuration.
For now I just set:
controller.jobs.catalog.export.sitemap.baseurl
controller.jobs.catalog.export.sitemap.location
Re: Sitemap Job is not working correctly
Post by aimeos » 03 Aug 2022, 12:27
The sitemaps are gzip-ed because they can be very large and the search engines support gzip-ed files. You can usually uncompress them with tools provided by most OS.
billy678
Post by billy678 » 10 Aug 2022, 11:34
I tried too. Same result.
I used this advanced scheduler and added the id for the pages.
The sitemaps are generated but the urls are wrong because the detail page is ignored.
Post by aimeos » 10 Aug 2022, 11:38
Do you have an example and how it should look like?
billy678
Post by billy678 » 10 Aug 2022, 11:50
I added my scheduler config.
My urls in the sitemap currently look like this:
www.domain.com/d/My-Product
The real path is:
www.domain.com/shop/detail/d/My-Product
billy678
Post by billy678 » 10 Aug 2022, 12:16
Ok, never mind.
I've added
controller.jobs.product.export.sitemap.location = ../uploads/tx_aimeos/
controller.jobs.product.export.sitemap.baseurl = https://www.domain.com/shop/detail/
and it works!
So you have to use .product instead of .catalog
