Duplicate Select product without duplicating its variants
padawan
Post by padawan » 18 Aug 2022, 14:06
Hello everyone,
I'm new to Aimeos. I want to create a list of products each containing the same variants.
To do this, I first created a Select product containing a few variants. And to save time, I would like to duplicate this product already created. But I'm facing a problem: the duplicate product contains new variants that have also been copied.
Is there a solution to keep the same variants?
Thanks for your advices !
Re: Duplicate Select product without duplicating its variants
Post by aimeos » 19 Aug 2022, 06:02
You can remove the variant entries and re-add them. In that case, you can select from a list of suggested variant articles in the SKU field, which uses the existing article if you select one.
