How to import extensions
deepakdtpss
Post by deepakdtpss » 19 Aug 2022, 10:27
Query-1
Suppose I have created a new form. How can I do that with the custom extension?
Suppose there is an already new form and I want to add some more form or inputs to it. How Can I do that?
Query 2-
How can we override existing Profile modules?
aimeos/ai-client-html/src/Client/Html/Account/Profile/Standard.php
https://aimeos.org/docs/latest/frontend ... s/#example
>> I tried the example in the above doc getting an error \Aimeos\MW\View\Iface not found
Re: How to import extensions
Post by aimeos » 19 Aug 2022, 10:37
deepakdtpss wrote: 19 Aug 2022, 10:27 Suppose I have created a new form. How can I do that with the custom extension?
Where do you want to add a new form and what should it contain?
deepakdtpss wrote: 19 Aug 2022, 10:27 https://aimeos.org/docs/latest/frontend ... s/#example
Thanks for the hint, the documentation has been fixed now.
