Previous and next button not working.
pamirsawar
Post by pamirsawar » 24 Aug 2022, 07:05
Hello!
When I click on next or previous button, application takes me to wrong product url. Where endpoint has product label.
It should redirect to correct route. i.e not with the lable but SKU id.
VirtualSpy
Re: Previous and next button not working.
Post by VirtualSpy » 24 Aug 2022, 07:51
I was also facing this issue
Previous and Next option is not working
Post by aimeos » 24 Aug 2022, 07:53
Set this configuration to an empty array if your product URL segments are not unique:
https://aimeos.org/docs/2022.x/config/c ... il/#filter
Then, the product ID will be part of the URL, identifying the product uniquely.
pamirsawar
Post by pamirsawar » 24 Aug 2022, 09:28
aimeos wrote: 24 Aug 2022, 07:53 Set this configuration to an empty array if your product URL segments are not unique:
Thanks!! adding this solved the issue.
