How to hide buy button in catalog list?
oliwin4
Post by oliwin4 » 24 Aug 2022, 19:54
How to hide buy button in catalog list that I reused in home page?
Re: How to hide buy button in catalog list?
Post by aimeos » 26 Aug 2022, 10:04
If you don't want to show the button at all, you can set this configuration to FALSE in your ./config/shop.php:
https://aimeos.org/docs/2022.x/config/c ... basket-add
If only the product list on the home page should not display the button, you can hide it via CSS because page specific configuration isn't supported.
