Upgrade from 2021.10 to 2022.07 with custom extension
matteovg7
Post by matteovg7 » 25 Aug 2022, 07:50
i'm trying to upgrade Aimeos from 2021.10 to 2022.07 version.
I have a custom extensions under ext folder with some overrided classes with different names.
The 2022.07 version doesn't find the classes of the submanagers because of a wrong namespace.
This is the config/mshop.php file of the extension:
<?php
return [
    'coupon' => [
        'manager' => [
            'name' => 'CouponVG7',
            'code' => [
                'name' => 'CouponCodeVG7',
                'decorators' => [
                    'local' => ['CouponCodeCustomerId']
    'customer' => [
        'manager' => [
            'name' => 'CustomerVG7',
            'decorators' => [
                'local' => ['UsersIdPrint']
            'address' => [
                'name' => 'AddressVG7'
    'media' => [
        'manager' => [
            'name' => 'MediaVG7',
            'decorators' => [
                'local' => ['MediaIdPrint']
    'order' => [
        'manager' => [
            'name' => 'OrderVG7',
            'decorators' => [
                'local' => ['OrderIdPrint']
            'base' => [
                'name' => 'OrderBaseVG7',
                'address' => [
                    'name' => 'OrderBaseAddressVG7',
                    'decorators' => [
                        'local' => ['OrderBaseAddressAddFields']
                'product' => [
                    'name' => 'OrderBaseProductVG7',
                    'decorators' => [
                        'local' => ['OrderBaseProductIdPrint']
                'service' => [
                    'name' => 'OrderBaseServiceVG7'
    'product' => [
        'manager' => [
            'name' => 'ProductVG7',
            'decorators' => [
                'local' => ['ProductIdPrint', 'ProductCodePrint']
    'service' => [
        'manager' => [
            'name' => 'ServiceVG7',
            'decorators' => [
                'local' => ['ServiceIdPrint']
For example I have this error:
Class "\Aimeos\MShop\Customer\Manager\AddressVG7" not found
but the correct namespace for this class is
\Aimeos\MShop\Customer\Manager\Address\AddressVG7
It is changed something in the config array?
Thanks.
Re: Upgrade from 2021.10 to 2022.07 with custom extension
Post by aimeos » 26 Aug 2022, 10:18
The configuration didn't change but there are no manager factories any more and all managers are created by:
\Aimeos\MShop::create( $this->context(), '<domain>' );
Can you check if there's something fishy here?
https://github.com/aimeos/aimeos-core/b ... hp#L56-L88
matteovg7
Post by matteovg7 » 01 Sep 2022, 13:55
I opened a pull request: https://github.com/aimeos/aimeos-core/pull/297
I used it locally for some days and seem to be ok.
