Product not adding to the basket on the second site
pamirsawar
Post by pamirsawar » 25 Aug 2022, 09:22
Hello aimeos,
When I try to add a product to the basket it's not showing me the product.
I have added a price and did not set any stock value.
Aimeos version: 2022.07.2
php: 8.1
windows 10
Re: Product not adding to the basket on the second site
Post by aimeos » 26 Aug 2022, 10:20
If it's out of stock or if there's no stock at all, an error should be displayed.
How did you set up your products and sites because you said "on the second site"?
pamirsawar
Post by pamirsawar » 29 Aug 2022, 04:42
aimeos wrote: 26 Aug 2022, 10:20 If it's out of stock or if there's no stock at all, an error should be displayed.
I added a new site through admin backend. Ran setup command. and added products into that site.
In default site if product doesn't have stock value it still adds a product in the basket. but in the second site I have to add stock value in order for basket functionality to work for that product.
Post by aimeos » 30 Aug 2022, 07:21
By default, a stock entry is always required (even if empty which means "unlimited" stock) as long as you didn't configure Aimeos otherwise.
