After logged in second site error shows
pamirsawar
Post by pamirsawar » 25 Aug 2022, 13:28
Hello Aimeos.
I'm having this issue. When I try to log in into second site I'm seeing this on my screen
customer id fail.png (47.17 KiB) Viewed 16423 times
Re: After logged in second site error shows
Post by aimeos » 27 Aug 2022, 05:56
You are logged in with a user account from the first site, which isn't available on the second one.
If you want user accounts to be available at all sites, set the "siteid" column in the users table to an empty value.
peter69
Post by peter69 » 12 Jun 2023, 05:41
Hello!
Is there any configuration to allow users to log in with the same account on all sites?
Greetings,
Post by aimeos » 12 Jun 2023, 08:55
Yes, the "siteid" column in the "users" table needs to be an empty string.
