fixed and Percentage Rebate
viptapis
Post by viptapis » 30 Aug 2022, 11:32
Hello
is it possible to give fixed and Percentage Rebate together?
->https://tinyurl.com/2kdtv6bx
like give 5euro(FixedRebate) + 10% (PercentRebate) for single coupon.
Regards
Vip
Re: fixed and Percentage Rebate
Post by aimeos » 31 Aug 2022, 07:37
No, you can only select "Fixed" or "Percent" as provider when creating a new coupon but not both.
You can create your own decorator to add a fixed rebate on top of the price calculated by the "Percent" provider:
https://aimeos.org/docs/latest/provider ... decorators
