When extending jqadm attribute template It duplicate the page rendered
- ahmed31916
- Advanced
When extending jqadm attribute template src (vendor\aimeos\ai-admin-jqadm\src\Admin\JQAdm\Attribute\Standard.php), It duplicate the page rendered as shown in the attached image.
This is the code:
Maybe it is rendered twice (one from the extending class, and other from the vendor class).
This is the code:
namespace Aimeos\Admin\JQAdm\Common\Decorator;
class AttributeStandard
extends \Aimeos\Admin\JQAdm\Common\Decorator\Base
implements \Aimeos\Admin\JQAdm\Common\Decorator\Iface
}- Attachments
- Screenshot 2022-09-06 145124.png (109.83 KiB) Viewed 4010 times
Re: When extending jqadm attribute template It duplicate the page rendered
What's the implementation of the decorator class (what you've replaced by "...")?
- ahmed31916
- Advanced
this code:aimeos wrote: 07 Sep 2022, 16:12 What's the implementation of the decorator class (what you've replaced by "...")?
public function data( \Aimeos\Base\View\Iface $view ) : \Aimeos\Base\View\Iface
$all_makes = \Aimeos\Controller\Frontend::create( $this->context(), 'attribute' )
->compare( '==', 'attribute.type', 'Make' )
->sort( 'position' )->slice( 0, 10000 )->search();
$view->all_makes = $all_makes;
$view->itemSubparts = $this->getSubClientNames();
$view->itemTypes = $this->getTypeItems();
return $view;
public function batch() : ?string
return $this->batchBase( 'attribute' );
public function get() : ?string
$view = $this->object()->data( $this->view() );
try
if( ( $id = $view->param( 'id' ) ) === null )
$msg = $this->context()->translate( 'admin', 'Required parameter "%1$s" is missing' );
throw new \Aimeos\Admin\JQAdm\Exception( sprintf( $msg, 'id' ) );
$manager = \Aimeos\MShop::create( $this->context(), 'attribute' );
$view->item = $manager->get( $id, $this->getDomains() );
$view->itemData = $this->toArray( $view->item );
$view->itemBody = parent::get();
catch( \Exception $e )
$this->report( $e, 'get' );
return $this->render( $view );
public function save() : ?string
$view = $this->view();
$manager->begin();
try
$item = $this->fromArray( $view->param( 'item', [] ) );
$view->item = $item->getId() ? $item : $manager->save( $item );
$view->itemBody = parent::save();
$manager->save( clone $view->item );
$manager->commit();
if(request()->make !== null){
$attr_model_id = request()->item['attribute.id'] ?? $view->item->getId();
$attr_model_id_check = AttributeList::where('parentid', $attr_model_id)->first();
return $this->redirect( 'attribute', $view->param( 'next' ), $view->item->getId(), 'save' );
$manager->rollback();
$this->report( $e, 'save' );
return $this->create();
public function getSubClient( string $type, string $name = null ) : \Aimeos\Admin\JQAdm\Iface
return $this->createSubClient( 'attribute/' . $type, $name );
protected function getDomains() : array
return $this->context()->config()->get( 'admin/jqadm/attribute/domains', [] );
protected function getSubClientNames() : array
return $this->context()->config()->get( 'admin/jqadm/attribute/subparts', [] );
protected function getTypeItems() : \Aimeos\Map
$typeManager = \Aimeos\MShop::create( $this->context(), 'attribute/type' );
$search = $typeManager->filter( true )->slice( 0, 10000 );
$search->setSortations( [$search->sort( '+', 'attribute.type.label' )] );
return $typeManager->search( $search );
} protected function fromArray( array $data ) : \Aimeos\MShop\Attribute\Item\Iface
if( isset( $data['attribute.id'] ) && $data['attribute.id'] != '' ) {
$item = $manager->get( $data['attribute.id'], $this->getDomains() );
} else {
$item = $manager->create();
$item->fromArray( $data, true );
return $item;
protected function toArray( \Aimeos\MShop\Attribute\Item\Iface $item, bool $copy = false ) : array
$data = $item->toArray( true );
if( $copy === true )
$data['attribute.siteid'] = $this->context()->locale()->getSiteId();
$data['attribute.code'] = $data['attribute.code'] . '_' . substr( md5( microtime( true ) ), -5 );
$data['attribute.id'] = '';
return $data;
protected function render( \Aimeos\Base\View\Iface $view ) : string
$tplconf = 'admin/jqadm/attribute/template-item';
$default = 'attribute/item';
return $view->render( $view->config( $tplconf, $default ) );
You've copied the code from the attribute JQAdm class more or less into your new decorator and this is wrong. A decorator should only add additional or modify existing data and must only contain code for that.
