Missing Icons withg TYPO3 11.5.15 and Aimeos 21.10.7
timschreiner
Post by timschreiner » 07 Sep 2022, 07:40
we are using Aimeos 21.10.7 LTS with TYPO3 11.5.15 and PHP 8.0 on a linux machine right now and experiencing missing Icons within the Aimeos backend.
I read in other Posts, that an update to latest minor version should fix this problem, this 21.10.7 is the latest version right now.
Screenshot from 2022-09-07 09-33-53.png (29.92 KiB) Viewed 5051 times
Is there any advice for fixing this issue? Or is this issue be fixed with version 22 (is there a release date for 22 LTS yet, so that we can consider to postpone the relaunch?)
Thank you for your help.
Re: Missing Icons withg TYPO3 11.5.15 and Aimeos 21.10.7
Post by aimeos » 08 Sep 2022, 15:46
We can't reproduce the problem.
A fresh installation of TYPO3 11.5.15 and Aimeos 21.10.7 shows no missing icons in the backend.
However, Aimeos 21.10.6 and before have that problem so maybe your update to 21.10.7 didn't work correctly.
timschreiner
Post by timschreiner » 09 Sep 2022, 07:16
Hi thanks for your reply. You information, that the update did not work correctly, lead me to the problem.
So for everyone else having this problem. Make sure when you update
aimeos/aimeos-typo3
you update also its dependencies ... (in my case from 21.10.6 to 21.10.7)
Thanks for your time and sorry for this rookie mistake.
