Extending Managers in 22.7.x
heural
Post by heural » 16 Sep 2022, 07:48
Hi Aimeos-Team,
i have extended the order-manager and order-product-manager to add some data to the objects, as you can see in the screenshot. That had worked in Version 22.4.x.
But in 22.7.1 in the frontend the message
Class "\Aimeos\MShop\Order\Manager\Myorder" not found
appears.
What i am doing wrong?
2022-09-16 09_38_02-Greenshot.png (31.28 KiB) Viewed 2826 times
Thanks a lot!
Re: Extending Managers in 22.7.x
Post by aimeos » 16 Sep 2022, 08:03
Please update to the newly released 22.7.2 version, which should fix the problem.
