CSV Product Options
yeh
CSV Product Options
Post by yeh » 27 Sep 2022, 12:16
I'm currently setting up my CSV import mapping and cannot see anywhere to set product options (https://aimeos.org/docs/2022.x/manual/p ... s/#options).
Is there a mapping option for these or do they have to be set manually using jqadm?
Re: CSV Product Options
Post by aimeos » 28 Sep 2022, 11:28
These are standard product attributes with a product.lists.type of "config" or "custom".
yeh
Post by yeh » 28 Sep 2022, 11:53
Ah perfect! Thank you for the explanation.
