Stock import CSV mapping
yeh
Post by yeh » 27 Sep 2022, 13:36
I can see there is a stock import job. There are a number of options to control the various aspects of this, but I can't find what the mapping should be for the CSV file https://aimeos.org/docs/2022.x/config/c ... mport/#csv
Is it similar to the main product import CSV with just the product code and stock entries or is it using a different mapping entirely?
Re: Stock import CSV mapping
Post by aimeos » 28 Sep 2022, 11:34
The product stock import has a fixed file layout:
<productcode>,<stocklevel>[,<stocktype>[,<backdate]]
yeh
Post by yeh » 28 Sep 2022, 11:54
I see, thank you.
