Where is the order export saved?
promptnet
Post by promptnet » 10 Oct 2022, 07:27
I'm wondering where the order export is saved by default
Thanks!
Aimeos: 21.10.7
PHP: 7.4.30
Linux
(TYPO3: 10.4.31)
Re: Where is the order export saved?
Post by aimeos » 11 Oct 2022, 06:09
This is the default path for order export files:
https://github.com/aimeos/aimeos-typo3/ ... ce.php#L30
You should download them from the dashboard where you can also delete them afterwards.
promptnet
Post by promptnet » 12 Oct 2022, 09:02
Thanks for your answer, but neither are there exports in the given directory, nor do I have the possibility to export in the dashboard.
Post by aimeos » 12 Oct 2022, 11:23
Make sure you've set up a scheduler task (order/export/csv) that creates the files:
https://aimeos.org/docs/latest/typo3/se ... ery-minute
promptnet
Post by promptnet » 12 Oct 2022, 13:55
Ah, cool. Thanks.
Now it works perfectly.
