changes in jqadm templates not affect
mojanimator
hi
i followed the instructions for creating extension. i have copied client html sections in my extensions and changes works perfect.
but about jqadm section:
i copied from vendor/ai-admin-jqadm/templates/admin/jqadm
to
packages/[my theme name]/templates/admin/jqadm
but changes in files (for example page.php) not affect at all,
i cleared cache with aimeos:clear but not any success
am i doing somethings wrong?
the only solution i have found was comment my theme name in manifest . but i dont think this is the true way
to
- VirtualSpy
- Advanced
Re: changes in jqadm templates not affect
did yo run cmdmojanimator wrote: 13 Oct 2022, 18:03 hi
to
composer upRe: changes in jqadm templates not affect
You've created a Laravel theme extension and there, the theme files are only used if you select the theme for the current site in the frontend. For the admin backend, separate themes are not supported yet and the "admin/jqadm/templates" key must be outside the section of your theme template configuration in the manifest.php, i.e.:mojanimator wrote: 13 Oct 2022, 18:03 the only solution i have found was comment my theme name in manifest . but i dont think this is the true way
'template' => [
'admin/jqadm/templates' => [
'templates/admin/jqadm',
'admin/jsonadm/templates' => [
'templates/admin/jsonadm',
'client/jsonapi/templates' => [
'templates/client/jsonapi',
'my-aimeos-ext' => [
'client/html/templates' => [
'templates/client/html',
'controller/jobs/templates' => [
'templates/controller/jobs',
mojanimator
yes. i changed site theme in frontend admin panel and made manifest changes . i made changes in packages/[my theme]/views/page/index.blade.php but not any changes affected. but changes in packages/[my theme]/views/base.blade.php affects perfectly . i dont know the reasonaimeos wrote: 14 Oct 2022, 07:59You've created a Laravel theme extension and there, the theme files are only used if you select the theme for the current site in the frontend. For the admin backend, separate themes are not supported yet and the "admin/jqadm/templates" key must be outside the section of your theme template configuration in the manifest.php, i.e.:mojanimator wrote: 13 Oct 2022, 18:03 the only solution i have found was comment my theme name in manifest . but i dont think this is the true wayCode: Select all
'template' => [ 'admin/jqadm/templates' => [ 'templates/admin/jqadm', ], 'admin/jsonadm/templates' => [ 'templates/admin/jsonadm', ], 'client/jsonapi/templates' => [ 'templates/client/jsonapi', ], 'my-aimeos-ext' => [ 'client/html/templates' => [ 'templates/client/html', ], 'controller/jobs/templates' => [ 'templates/controller/jobs', ], ], ],
my extension manifest:
packages/[my theme]/views/page/index.blade.php (any changes not affect)
Maybe a few things to check:
- Views could be cached (run: php artisan optimize:clear)
- The page/index view could be overwritten in ./resources/views/vendor/
i am facing a similar problem with aimeos 2022.x and a custom laravel theme.
A change to the "<custom-theme>/views/jqadm/index.blade.php" file is not rendered in the admin area.
I run the "php artisan optimize:clear" and the directory "storage/framework/views" is empty afterwards.
In "./resources/views/vendor/" is nothing regarding jqadm or admin.
Reloading the admin dashboard creates a new file in "storage/framework/views".
The last contains a origin path: /vendor/aimeos/aimeos-laravel/src/views/jqadm/index.blade.php
So i guess the themes "jqadm/index.blade.php" isn't used. The custom.js und custom.css for example are included in the admin sourcecode.
Maybe i am missing something?
Overwriting Blade templates in a theme extension isn't supported (backend doesn't support themes in that way) and you have to put your overwritten Blade template to ./Resources/views/shop/jqadm/ instead.
See: https://aimeos.org/docs/latest/laravel/ ... -templates
Thx for the reply.
We solved this by using custom.js and custom.css plus an own api controller for getting the needed data for the javascript.
So the template isn't needed to be overridden.
