about creating the new components
mahammadareef
Post by mahammadareef » 18 Oct 2022, 06:30
hey, i tried creating the new component by -> templates\client\html\<nameofthecomponent> and its classes and source code inside -> \src\Client\Html\<ComponentName> but its not working , i know how to crearte sub parts inside components folder and its working .
is it required to register the new components in aimeos?
can you help me with detailed steps and examples to create a new component using EXTRAUSECOMPONENT as the name of a component
Re: about creating the new components
Post by aimeos » 19 Oct 2022, 07:03
You have to add your new component to one of the page types in your configuration:
https://github.com/aimeos/aimeos-larave ... hp#L27-L41
Then, the body and header methods are called by the controller:
https://github.com/aimeos/aimeos-larave ... hp#L58-L62
Finally, you have to add the output of the body/header methods to the Blade template. Copy the Blade template to ./resources/views/vendor/shop/catalog/detail.blade.php and add the output of the body/header methods there:
- https://aimeos.org/docs/latest/laravel/ ... -templates
- https://github.com/aimeos/aimeos-larave ... .blade.php
