how to add jquery and bootstrap to aimeos
mahammadareef
Post by mahammadareef » 19 Oct 2022, 11:56
I want to redesign the header and footer parts of the aimeos site by using bootstrap CSS and jquery library, and also don't want this code to affect the remaining parts of the templates like basket standard body, shop page content, profile page content, etc. how can I achieve this ... explain this in easy steps, please...
Re: how to add jquery and bootstrap to aimeos
Post by aimeos » 20 Oct 2022, 15:25
Bootstrap is already part of the Aimeos theme:
https://github.com/aimeos/ai-client-htm ... lt/app.css
Also, Aimeos uses a jQuery compatible library named cash-dom, which offers the same API methods if modern browsers doesn't provide a better alternative:
- https://github.com/fabiospampinato/cash
- https://github.com/aimeos/ai-client-htm ... ult/app.js
mahammadareef
Post by mahammadareef » 26 Oct 2022, 09:35
when i tried adding jquery there is error in aimeos.js file of my theme extension , in this code block
* Initializes offscreen menus
setupOffscreen() {
$('.zeynep').each((idx, el) => {
$(el).zeynep({});
for error check the attactchment
Post by aimeos » 27 Oct 2022, 14:48
We don't recommend to use jQuery at all because we are using cash-dom as modern replacement.
mahammadareef
Post by mahammadareef » 08 Nov 2022, 10:39
I am finding difficulty in integrating slick slider BCS slick slider requires jquery, and not only this almost packages need jquery ,,and cash dom comes with very less functionalities,is there any safe way we can add jquery without affecting the code ..
Post by aimeos » 08 Nov 2022, 18:58
Only if you create your own theme.
Using the default theme, SwiffySlider is used instead:
https://swiffyslider.com/
mahammadareef
Post by mahammadareef » 09 Nov 2022, 05:28
yes in new theme i wan to add jquery
