How to avoid having to use "composer update" when changing CSS and JS files in my theme extension?
kdim95
Post by kdim95 » 23 Oct 2022, 20:57
Laravel framework version: 9.36.4
Aimeos Laravel version: * 2022.07.2
PHP Version: 8.1.9
Environment: Linux
I have created a theme extension and selected it.
Every time I change a CSS or JS file in...
vendor/aimeos-themes/mytheme/themes/client/html/mytheme/*.css
The changes don't reflect on the frontend without doing composer up
How can you temporarily avoid the entire process of having to execute composer up every time and use the theme files directly from the extension?
I can edit the files directly in...
public/vendor/shop/themes/mytheme
But I don't want to accidentally overwrite them with composer up at a later point.
Re: How to avoid having to use "composer update" when changing CSS and JS files in my theme extension?
Post by aimeos » 24 Oct 2022, 17:34
You can link the ./packages/<extname>/themes/ folder of your extension to ./public/vendor/shop/themes/<extname>/ directory.
kdim95
Post by kdim95 » 25 Oct 2022, 08:04
I'm sorry, how do you 'link' it :)
Post by aimeos » 25 Oct 2022, 08:12
Use the Linux command line utility "ln":
https://linuxize.com/post/how-to-create ... n-command/
kdim95
Post by kdim95 » 25 Oct 2022, 10:01
I tried the following links
ls - s ./packages/<extname>/themes ./public/vendor/shop/themes/<extname>
ln -s ./packages/<extname>/themes/client/html/<extname> ./public/vendor/shop/themes/<extname>
it keeps looking for the files in ./public/vendor/shop/themes/<extname>
kdim95
Post by kdim95 » 25 Oct 2022, 10:20
I solved it by providing the full paths when linking:
ln -s /var/www/vhosts/<domain>/httpdocs/packages/<extname>/themes/client/html/<extname> /var/www/vhosts/<domain>/httpdocs/public/vendor/shop/themes/<extname>
And for removal of the link, the command is:
unlink /var/www/vhosts/<domain>/httpdocs/public/vendor/shop/themes/<extname>
Should be noted that before linking to .../public/vendor/shop/themes/<extname>, the directory had to be deleted.
It will not link properly if the public theme directory already exists.
For listing of symbolic links to the directory, the command is:
ls -l /var/www/vhosts/<domain>/httpdocs/public/vendor/shop/themes/<extname>
peter69
Post by peter69 » 25 Oct 2022, 19:28
You saved my life!!!
Thank you so much!!
