airoute not works inside components
mahammadareef
Post by mahammadareef » 27 Oct 2022, 12:59
I tried using this code inside my components but it fails to generate a URL
{{ airoute( 'aimeos_shop_account' ) }}
this works in the base.blade.php file but not in my component template file
please help me with this,
thanks in advance
Re: airoute not works inside components
Post by aimeos » 28 Oct 2022, 07:06
In the Aimeos templates, you have to use e.g.:
<?= $enc->attr( $this->link( 'client/html/catalog/detail', ['d_prodid' => 123] ) ) ?>
