Adding Google Model Viewer in Products
- ARJIEANGELOG.VICUNA
Good day, i am very new to your platform, i want to add the google model viewer as a replacement or new function in displaying a product, but i do not know how i can implement it, may i ask for your assistance for this problem.
Thank you in advance
Re: Adding Google Model Viewer in Products
First allow uploading the mimetype of the models by adding it using this configuration:
https://github.com/aimeos/aimeos-core/b ... #L574-L605
Then, we need to add the required HTML for the models here:
https://github.com/aimeos/ai-client-htm ... andard.php
If you create a pull request with your changes, we will be happy to merge them
Good day Aimeos, may i ask again what is the directory where i can add a unpkg cdn for my google model viewer
You can store it to the themes folder and add it conditionally in the header here:
https://github.com/aimeos/ai-client-htm ... hp#L77-L78
Hello aimeos i did follow what you told me but i still may have a problem saving the file
I did try to insert the cdn with echo in the public header in the standard.php, because it is the only file in the catalog/detail:
And then i included the mimetype in the default variable:
And then for the viewing of the model here i used elseif for the new media
But saving the gltf file in the database is empty
i am very sorry for disturbing and looking forward for a response thank you in advance
public function header( string $uid = '' ) : ?string
$view = $this->view();
$config = $this->context()->config();
$prefixes = ['d_prodid', 'd_name'];
$confkey = 'client/html/catalog/detail';
$code = $config->get( 'client/html/catalog/detail/prodcode-default' );
$id = $config->get( 'client/html/catalog/detail/prodid-default', $code );
echo '<script type="module" src="https://unpkg.com/@google/model-viewer/dist/model-viewer.min.js"></script>';
if( !$view->param( 'd_name', $view->param( 'd_prodid', $id ) ) ) {
return '';
if( $html = $this->cached( 'header', $uid, $prefixes, $confkey ) ) {
return $this->modify( $html, $uid );
$default = [
'image/webp', 'image/jpeg', 'image/png', 'image/gif', 'image/svg+xml',
'application/pdf', 'application/zip',
'video/mp4', 'video/webm'.
'model/gltf+json', 'model/gltf-binary'
if( !strncmp( $media->getMimetype(), 'video/', 6 ) )
return '
<video autoplay muted class="item" id="image-' . $media->getId() . '" loading="lazy"
thumbnail="' . $enc->attr( $view->content( $media->getPreview(), $media->getFileSystem() ) ) . '"
poster="' . $enc->attr( $view->content( $media->getPreview( 600 ), $media->getFileSystem() ) ) . '"
src="' . $enc->attr( $view->content( $media->getUrl(), $media->getFileSystem() ) ) . '"
alt="' . $enc->attr( $media->getProperties( 'title' )->first( $media->getName() ) ) . '"
' . $variant . ' />
</video>
}elseif( !strncmp( $media->getMimetype(), 'model/', 6 )){
return '
<model-viewer class="item" id="image-' . $media->getId() . '" loading="lazy"
' . $variant . ' ar auto-rotate camera-controls>
</model-viewer>
- db.png (7.35 KiB) Viewed 5029 times
You have to add the script file here:ARJIEANGELOG.VICUNA wrote: 01 Nov 2022, 02:07 I did try to insert the cdn with echo in the public header in the standard.php, because it is the only file in the catalog/detail:
The gltf file is stored according to your screenshot but there's no preview image generated because this works only for images.
