Javascript errors
Wall0fDeath
Javascript errors
Post by Wall0fDeath » 02 Nov 2022, 15:46
Laravel - 9
Aimeos - 2022.10 latest
jQuery - v3.3.1 (as it says in the javascript file)
JqueryUI - 1.12.1 ( as it says in the aimeos.js )
I get the following errors during js load:
1:
Uncaught TypeError: Cannot read properties of undefined (reading 'ui') aimeos.js?v=1:6
2: (I guess this is a result of the first error)
Uncaught ReferenceError: Aimeos is not defined
at Object.onSearchSuppliers (catalog-filter.js?v=1:303)
at Object.init (catalog-filter.js?v=1:410)
at catalog-filter.js?v=1:424
My Laravel is running in a docker (Debian GNU/Linux 11 (bullseye)), the CSP now lets everything through with unsafe-inline.
It was installed as laravel package as it says in the install guide.
I 'd like to ask for a little help with this issue.
If this is a version problem is there any 'nice' way, to update the used js?
Thank you in advance
Re: Javascript errors
Post by aimeos » 03 Nov 2022, 10:26
The mentioned aimeos.js file isn't something from the official Aimeos source - at least not in the admin backend.
Where does that file comes from?
