Programaticaly import products no csv
NoAd
Post by NoAd » 03 Nov 2022, 20:06
Hello, I;m new to aimeos.
Is there a class that will help mass add products? i got product list from json api.
In documentation i found that i should probably use theese:
https://aimeos.org/docs/2022.x/models/managing-items/
$manager = \Aimeos\MShop::create( $context, 'product' );
$item = $manager->create(/* pass some data from my json api here */);
but I can't get what to send as $context inside laravel
I use laravel 9.38 (latest), php 8.1, aimeos 2022.x (latest) on VPS/linux debian 11 on apache 2.4
I try to implement aimeos product import inside laravel nova action.
Can someone show a laravel code example for creating one empty item?
below some code example for easier anwser:
<?php
namespace App\Nova\Actions\Aimeos;
use Illuminate\Bus\Queueable;
use Illuminate\Contracts\Queue\ShouldQueue;
use Illuminate\Queue\InteractsWithQueue;
use Illuminate\Support\Collection;
use Laravel\Nova\Actions\Action;
use Laravel\Nova\Fields\ActionFields;
use Laravel\Nova\Http\Requests\NovaRequest;
class ImportProduct extends Action
    use InteractsWithQueue, Queueable;
     * Perform the action on the given models.
     * @param  \Laravel\Nova\Fields\ActionFields  $fields
     * @param  \Illuminate\Support\Collection  $models
     * @return mixed
    public function handle(ActionFields $fields, Collection $models)
    		$manager = \Aimeos\MShop::create( $context, 'product' ); //Call to product manager; But what to send as $context?
    		$item = $manager->create(); // create empty item
    		/* this code returns a error: Unidentified variable $context */
NoAd
Re: Programaticaly import products no csv
Post by NoAd » 06 Nov 2022, 08:59
any support in this case will be appreciated
Post by aimeos » 06 Nov 2022, 19:15
Use this to get the Aimeos context and create a new item:
$context = app('aimeos.context')->get();
$item = $manager->create()->setCode( 'test' );
$manager->save( $item );
Documentation: https://aimeos.org/docs/latest/laravel/ ... os-objects
