Error hidding and change mandatory fields
YnievesPuntoNet
Post by YnievesPuntoNet » 04 Nov 2022, 18:57
I modified the file 'config/shop.php' for hidding some fields but i dont show any change.
            'checkout' => [
                'standard' => [
                    'address' => [
                        'billing' => [
                            'mandatory' => [
                                'order.base.address.firstname',
                                'order.base.address.countryid',
                            'hidden' => [
                                'order.base.address.salutation',
                                'order.base.address.vatid',
                        'delivery' => [
                            'mandatory' => [
                            'hidden' => [
Any idea.
Best Regards
YnievesPuntoNet
Re: Error hidding and change mandatory fields
Post by YnievesPuntoNet » 05 Nov 2022, 00:52
Well, continue the testing, this changes affect the form in summary checkout, but not in profile.
how I can change this data globally?
Post by aimeos » 06 Nov 2022, 19:31
You have to overwrite this file in your own extension because there's no global configuration for that:
https://github.com/aimeos/ai-client-htm ... e/body.php
YnievesPuntoNet
Post by YnievesPuntoNet » 08 Nov 2022, 19:32
Thanks, I work in that then.
Thanks for Aimeos
peter69
Post by peter69 » 06 Dec 2022, 19:34
You could validate whether or not to display the fields according to the billing/delivery configuration of the checkout settings:
<?php if (!in_array('order.base.address.salutation', $this->config('client/html/checkout/standard/address/delivery/hidden') , true)): ?>
	<div class="form-item form-group row salutation">
	</div>
<?php endif; ?>
