Admin template cannot accept the translation from the i18n file
- ahmed31916
- Advanced
Hello Aimeos,
I used to translate texts like this : "$this->translate( 'client', 'Text' )" in the client templates folder, of the extension.
Now, I'm trying to edit the translations in the subpart: "packages\test\templates\admin\jqadm\product\item.php", in the admin template, of the extension. I wrote "$this->translate( 'client', 'Text' )", but it cannot accept the translation from the file "packages\test\i18n\en.po". Why?
Re: Admin template cannot accept the translation from the i18n file
The translation domain is "admin", not "client" in the admin backend.
- ahmed31916
- Advanced
Ok, also "admin" doesn't work.
In another hand, if I used "admin", where I should to store "en.po" file extended?
In the ./i18n/ directory of your extension. Please remember that you have to use msgfmt command to create a binary MO file from your .php file:ahmed31916 wrote: 06 Nov 2022, 19:51 In another hand, if I used "admin", where I should to store "en.po" file extended?
https://aimeos.org/docs/latest/developer/translations/
The easiest way is to add translations to your ./config/shop.php:
https://aimeos.org/docs/latest/laravel/ ... anslations
