Payment email exception for payed orders
Moritz
Post by Moritz » 10 Nov 2022, 06:54
When I make an order (payment received) and execute the order/email/payment job I get the following exception.
Error while trying to send payment e-mail for order ID "1215" and status "6": ID parameter needs to be passed for the cHash calculation!
#0 /var/www/typo3_src-11.5.17/typo3/sysext/core/Classes/Routing/PageRouter.php(498): TYPO3\CMS\Frontend\Page\CacheHashCalculator->getRelevantParameters()
#1 /var/www/typo3_src-11.5.17/typo3/sysext/core/Classes/Routing/PageRouter.php(484): TYPO3\CMS\Core\Routing\PageRouter->getCacheHashParameters()
#2 /var/www/typo3_src-11.5.17/typo3/sysext/core/Classes/Routing/PageRouter.php(372): TYPO3\CMS\Core\Routing\PageRouter->generateCacheHash()
#3 /var/www/typo3_www.ami-informiert.de/typo3conf/ext/aimeos/Resources/Libraries/aimeos/ai-typo3/src/Base/View/Helper/Url/T3Router.php(69): TYPO3\CMS\Core\Routing\PageRouter->generateUri()
#4 [internal function]: Aimeos\Base\View\Helper\Url\T3Router->transform()
#5 /var/www/typo3_www.ami-informiert.de/typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-base/src/View/Standard.php(87): call_user_func_array()
#6 /var/www/typo3_www.ami-informiert.de/typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-base/src/View/Helper/Link/Standard.php(47): Aimeos\Base\View\Standard->__call()
#7 [internal function]: Aimeos\Base\View\Helper\Link\Standard->transform()
#8 /var/www/typo3_www.ami-informiert.de/typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-base/src/View/Standard.php(87): call_user_func_array()
#9 /var/www/typo3_www.ami-informiert.de/typo3conf/ext/aimeos/Resources/Libraries/aimeos/ai-controller-jobs/templates/order/email/payment/html.php(132): Aimeos\Base\View\Standard->__call()
#10 /var/www/typo3_www.ami-informiert.de/typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-base/src/View/Standard.php(281): include('/var/www/typo3_...')
#11 /var/www/typo3_www.ami-informiert.de/typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-base/src/View/Standard.php(263): Aimeos\Base\View\Standard->includeFile()
#12 /var/www/typo3_www.ami-informiert.de/typo3conf/ext/aimeos/Resources/Libraries/aimeos/ai-controller-jobs/src/Controller/Jobs/Order/Email/Payment/Standard.php(466): Aimeos\Base\View\Standard->render()
#13 /var/www/typo3_www.ami-informiert.de/typo3conf/ext/aimeos/Resources/Libraries/aimeos/ai-controller-jobs/src/Controller/Jobs/Order/Email/Payment/Standard.php(330): Aimeos\Controller\Jobs\Order\Email\Payment\Standard->send()
#14 /var/www/typo3_www.ami-informiert.de/typo3conf/ext/aimeos/Resources/Libraries/aimeos/ai-controller-jobs/src/Controller/Jobs/Order/Email/Payment/Standard.php(238): Aimeos\Controller\Jobs\Order\Email\Payment\Standard->notify()
#15 /var/www/typo3_www.ami-informiert.de/typo3conf/ext/aimeos/Classes/Scheduler/Base.php(60): Aimeos\Controller\Jobs\Order\Email\Payment\Standard->run()
#16 [internal function]: Aimeos\Aimeos\Scheduler\Base::Aimeos\Aimeos\Scheduler\closure()
#17 /var/www/typo3_www.ami-informiert.de/typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-base/src/Process/None.php(44): call_user_func_array()
#18 /var/www/typo3_www.ami-informiert.de/typo3conf/ext/aimeos/Classes/Scheduler/Base.php(63): Aimeos\Base\Process\None->start()
#19 /var/www/typo3_www.ami-informiert.de/typo3conf/ext/aimeos/Classes/Scheduler/Task/Typo6.php(41): Aimeos\Aimeos\Scheduler\Base::execute()
It occurs on this line.
PHP 8.2.24
Typo3 v12.4.23 LTS
Aimeos web shop 24.10.2
Re: Payment email exception for payed orders
Post by aimeos » 11 Nov 2022, 05:55
Either you've used the standard Aimeos scheduler task instead of the Aimeos advanced scheduler task where you have to enter the IDs of the required pages or you've added a route enhancer rule which requires an ID which isn't passed as parameter to the URI builder.
Moritz
Post by Moritz » 11 Nov 2022, 06:57
I use the Standard Aimeos scheduler task.
When I change the payment status of an order back to "waiting" and execute the job again I receive an email.
PHP 8.2.24
Typo3 v12.4.23 LTS
Moritz
Post by Moritz » 25 Nov 2022, 09:29
With the Aimeos advanced scheduler task I get the same error.
I have not added a additional route enhancer.
PHP 8.2.24
Typo3 v12.4.23 LTS
Moritz
Post by Moritz » 25 Nov 2022, 09:32
Strange is, that I get a mail when the status is on "pending".
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 25 Nov 2022, 09:44
Maybe this problem is related to an issue another user pointed us to and which we've fixed recently:
https://github.com/aimeos/aimeos-typo3/ ... 1f902ae92e
Moritz
Post by Moritz » 25 Nov 2022, 09:49
I'am the other user 😉
So the page ID is saved correctly in the task for me.
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 25 Nov 2022, 10:13
The TYPO3 error "ID parameter needs to be passed for the cHash calculation!" states that the page ID is missing when generating the URL for the account download page:
$this->link( 'client/html/account/download/url', ['dl_id' => $attribute->getId()], ['absoluteUri' => 1] )
Code can be found here:
https://github.com/aimeos/ai-controller ... l.php#L132
This means, the page ID for the account download page isn't set. Maybe that helps debugging.
Moritz
Post by Moritz » 25 Nov 2022, 10:22
That make sense.
I debugged the error and found out, that it occurs when creating the download URL with an id = 0.
Next I try to find out why it's zero.
PHP 8.2.24
Typo3 v12.4.23 LTS
Moritz
Post by Moritz » 25 Nov 2022, 11:10
Maybe you can evaluate it better.
I found out, that the result ($target) for the config "client/html/account/download/url" is null.
Because for the config the default value (null) is returned.
PHP 8.2.24
Typo3 v12.4.23 LTS
