saving the search data
mahammadareef
Post by mahammadareef » 10 Nov 2022, 10:39
if I want to save the search term of visitors how it can be done
please specify the step-by-step procedure ..
and attach the documents
Re: saving the search data
Post by aimeos » 11 Nov 2022, 06:07
You can either install Matomo which is designed for tracking users and their actions/input or create a decorator for the catalog/list component that tests if the f_search parameter is empty and writes it to the database if not. How to create and configure a decorator is described here:
https://aimeos.org/docs/latest/frontend ... omponents/
