filter product id by pattern matching =~
IvanIgniter
Post by IvanIgniter » 16 Nov 2022, 04:37
I am using laravel 6.x, PHP 7.4, Docker desktop/Ubuntu and the Aimeos 2021 (aimeos-laravel: 2021.10.4 / aimeos-core: 2021.10.13)
I would like to make a filter product.id using =~ like search for '1' should return like '1', '111', '123' etc.
I tried $search = $manager->filter( false, true )->add( 'order.id', '=~', '1' ) but return only 1 row '1'.
I tried examples from docs https://aimeos.org/docs/latest/models/search-filter/ but no luck.
Please help what is the best way to filter id not string column?
Re: filter product id by pattern matching =~
Post by aimeos » 17 Nov 2022, 06:38
Enable debug logging (madmin/log/manager/loglevel = 7) and check the generated SQL statement to see what happens.
IvanIgniter
Post by IvanIgniter » 18 Nov 2022, 03:10
I am not sure where to set the loglevel = 7. Is that correct?
I would like to emphasize that there were no error while searching using =~ in order.id but why it will only return one exact match? But if I tried it with string filter =~ to a string column would return the correct expect values.
Post by aimeos » 19 Nov 2022, 05:25
The config is in your ./config/shop.php file:
https://github.com/aimeos/aimeos/blob/m ... p.php#L196
Even if there's no error, you need to see what SQL statement is generated to find out why the "=~" operator isn't behaving as expected.
IvanIgniter
Post by IvanIgniter » 22 Nov 2022, 04:19
Ok this is the log output after searching "2" after searching 27 orders
Time: 2.9537677764893ms
Class: Aimeos\MShop\Order\Manager\Standard
SELECT COUNT( DISTINCT mord."id" ) AS "count"
FROM "mshop_order" AS mord
LEFT JOIN "mshop_order_base" AS mordba ON ( mord."baseid" = mordba."id" )
LEFT JOIN "mshop_order_base_product" AS mordbapr ON ( mordba."id" = mordbapr."baseid" )
WHERE ( ( mord."siteid" = '' OR mord."siteid" = '1.' ) AND ( mordba."siteid" = '' OR mordba."siteid" = '1.' ) AND ( mordbapr."siteid" = '' OR mordbapr."siteid" = '1.' ) AND ( ( mord."id" LIKE 2 ESCAPE '#' ) AND ( ( mordbapr."siteid" = '' OR mordbapr."siteid" = '1.' ) AND 1 = 1 ) ) )
Any idea what is causing the sql statement to be like AND ( ( mord."id" LIKE 2 ESCAPE '#' )?
Post by aimeos » 23 Nov 2022, 08:53
Guess, the order ID is casted to an integer value because the mshop_order.id column is defined as INT and the manager specifies it as "integer" too.
It also doesn't make much sense to apply the LIKE operator to an integer value, doesn't it?
IvanIgniter
Post by IvanIgniter » 24 Nov 2022, 03:38
Yap seems like but this is our requirements once a user search for id "1" it should be able to display id starting with 1.
From my sample screenshot sql statement, I wonder how to do this in Aimeos?
Post by aimeos » 25 Nov 2022, 08:51
You can try to overwrite the order manager class and replace PARAM_INT by PARAM_STR here:
https://github.com/aimeos/aimeos-core/b ... d.php#L142
IvanIgniter
Post by IvanIgniter » 25 Nov 2022, 12:01
Are you suggesting modifying the the aimeos core???
Is there any other way without modifying it?
Post by aimeos » 25 Nov 2022, 12:03
No, do that in your own project-specific extension, please!
