how to change the size of the suggested product options
- ahmed31916
- Advanced
Hello Aimeos,
Would you tell me how to change the size of the suggested product options in the admin panel?
- Screenshot 2022-11-16 120845.png (64.89 KiB) Viewed 4454 times
- ahmed31916
- Advanced
Re: how to change the size of the suggested product options
This is a combobox which filters the shown products (default: 25) depending on what you type in the input field.
