Poster does not work
Jieeezy
Post by Jieeezy » 20 Nov 2022, 15:14
i am using google model viewer as another media for product, but i need a custom poster before the resources is loaded, but i do not know why poster does not work in "vendor\aimeos\ai-client-html\src\Base\View\Helper\Image\Standard.php" but when i use a normal html the poster works. is there a way to make this work?
can you help me in this
Re: Poster does not work
Post by aimeos » 21 Nov 2022, 15:19
It requires some special code to create an image from the uploaded media which are not images.
For videos, you can see the code here:
https://github.com/aimeos/ai-admin-jqad ... #L112-L161
