TYPO3 Aimeos PayPal - Invalid Shipping total
we have here an Aimeos 21. 4. 1 within a TYPO3 V10 installation. This installation is composer-based.
In combination with PayPal, we notice the following error:
The customer wanted to create different shipping costs for two products, but under the product configuration in the range prices under shipping specified something different from 0 because the products were all shipped under the same shipping costs.
In this case, the shopping cart simply calculates both shipping costs together which is not really correct, it may be that I have overwritten the template incorrectly.
Unfortunately, the customer can not pay with PayPal at the place because then comes the following error message:
Re: TYPO3 Aimeos PayPal - Invalid Shipping total
Aimeos 21.4 isn't supported any more, you should update at least to 21.10 LTS.
Not sure if we understood correctly what you or your customer did.
Did you use the shipping costs per item in the price subpart of the product panel in the admin backend or not?
Did you make any customization for shipping cost calculation?
The customer has entered a value other than 0 at the place. This led to the mistake I have just mentioned.
Regarding the shipping costs, we have made adjustments in the front end and for the mail templates.
We want to update ASAP the Installation.
- Bildschirmfoto 2022-11-24 um 09.19.53.png (11.63 KiB) Viewed 7303 times
Maybe the problem is already fixed in later versions. If not, you should have a look here:
https://github.com/aimeos/aimeos-core/b ... #L693-L761
