ai-customergroups - Price missing
Moritz
Post by Moritz » 21 Nov 2022, 09:23
We use your ai-customergroups extension 2022.10.2.
When we add a new product with a price, the mshop_price.cgroups column is NULL (instead of 0) and no price is displayed in the frontend.
PHP 8.2.24
Typo3 v12.4.23 LTS
Aimeos web shop 24.10.2
nos3
Re: ai-customergroups - Price missing
Post by nos3 » 21 Nov 2022, 12:33
Did you configure the extension according to the ./vendor/aimeoscom/ai-customergroups/README.md file?
Moritz
Post by Moritz » 21 Nov 2022, 12:45
I think so. This is in my template on the root page.
PHP 8.2.24
Typo3 v12.4.23 LTS
Moritz
Post by Moritz » 25 Nov 2022, 08:53
A group is never saved for a price item.
Do I make a mistake in the configuration?
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 25 Nov 2022, 13:36
There was an optimization in the Aimeos core for saving items in all managers only if they or their dependent items have been modified. However, it turned out now that it doesn't work for dependent items of dependent items like
product -> list item (price) -> price -> list item (customer/group)
If only the list item for the customer/group item and the price item itself is marked as modified, the product item and the list item for the price is not. Therefore, those items aren't updated because it was expected that saving the product items also updates all dependent items along the dependency graph.
We've reverted the change back now. It's currently available in aimeos/aimeos-core:dev-master and aimeos/aimeos-core:2022.10.x-dev and a new release will be tagged soon.
Moritz
Post by Moritz » 25 Nov 2022, 13:45
Thank you very much for the fix!
Can you explain, how I create a prerelease by myself?
I don't use the composer mode.
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 25 Nov 2022, 14:21
Moritz
Post by Moritz » 28 Nov 2022, 10:07
With this version everything is saved correct i think.
Thank you very much!
PHP 8.2.24
Typo3 v12.4.23 LTS
Moritz
Post by Moritz » 08 Dec 2022, 12:35
I have the same trouble again.
Changes on existing price items are recognized and saved correcly (v22.10.4-pre2).
But when I add a new price item it is only showed in the backend.
In the frontend nothing is visible.
PHP 8.2.24
Typo3 v12.4.23 LTS
Moritz
Post by Moritz » 08 Dec 2022, 14:28
The same problem when I save an attribute (which has a price item) to a product and want to receive the attribute price in the frontend.
$attr->getRefItems('price', null, 'default')->toArray()
It doesn't work for new saved items and I get an empty array...
PHP 8.2.24
Typo3 v12.4.23 LTS
