Vue storefront
WarisAli
Vue storefront
Post by WarisAli » 21 Nov 2022, 14:26
PHP: 8.0.4,
Composer: 2.2.9,
System: Windows 10,
Laravel Version: 9.2,
Aimeos: 2022.10,
ai-elasticsearch: 2022.10.x-dev,
ai-cache: 2022.10
How can I integrate Vue storefrontend in laravel Aimeos. Please help me out.
Re: Vue storefront
Post by aimeos » 22 Nov 2022, 14:34
Integration requires to write an adapter between the Aimeos JSON API and VueStorefront:
- https://aimeos.org/docs/latest/frontend/jsonapi/
- https://docs.vuestorefront.io/v2/integr ... guide.html
peter69
Re: Vue storefront
Post by peter69 » 25 Nov 2022, 17:34
I think it would be a great boost to the project to have an example/code integrating VueStoreFront!
Re: Vue storefront
Post by aimeos » 25 Nov 2022, 18:33
Yes, we are also thinking that having a VueStorefront integration would be a great improvement for Aimeos users.
Who is willing to join forces with us to create such an integration?
peter69
Re: Vue storefront
Post by peter69 » 25 Nov 2022, 19:14
You can count on me!
skynet-technologies
Re: Vue storefront
Post by skynet-technologies » 28 Nov 2022, 13:08
We have already developed a Vuestorefront theme and it is compatible with Aimeos 2022.10
Currently we are just doing developer-level testing and it will be available within few weeks
Please feel free to let us know, in case anyone has any questions or comments.
Re: Vue storefront
Post by aimeos » 28 Nov 2022, 13:12
Will it be Open Source and do you have a Github repo?
peter69
Re: Vue storefront
Post by peter69 » 30 Nov 2022, 15:59
Let's hope so! :)
peter69
Re: Vue storefront
Post by peter69 » 09 Dec 2022, 16:29
I wonder if you need help to make VueStoreFront integration with Aimeos possible.
Or if you need me to run some tests, I'll be happy to help.
Regards!
Re: Vue storefront
Post by aimeos » 19 Dec 2022, 14:16
Got the new repo URL from Skynet :-)
https://github.com/skynetindia/vuestore-theme
