catalog supplier not showing
mahammadareef
Post by mahammadareef » 22 Nov 2022, 06:41
hello team aimeos
in the catalog filter, suppliers related to the catalog list are not showing in my aimeos latest version,
and I don't want to disable the supplier input check box I want to hide it, how I can do this
I am using the latest (version=2022.10.3) aimeos
Re: catalog supplier not showing
Post by aimeos » 23 Nov 2022, 09:30
mahammadareef wrote: 22 Nov 2022, 06:41 in the catalog filter, suppliers related to the catalog list are not showing in my aimeos latest version,
Version 2022.10 comes with an updated catalog supplier filter implementation, which allows filtering for suppliers dynamically to support large amounts of suppliers. If you update from previous versions, make sure that the CSS and JS files of your theme are up to date:
- https://github.com/aimeos/ai-client-htm ... #L278-L370
- https://github.com/aimeos/ai-client-htm ... filter.css
mahammadareef wrote: 22 Nov 2022, 06:41 and I don't want to disable the supplier input check box I want to hide it, how I can do this
To hide something, you can always use CSS display:none for example.
