BCC-Mail is not sent
Moritz
Post by Moritz » 02 Dec 2022, 13:53
When the payment mail is sent, no copy is sent to the bcc-email address.
I configured it in my resource.php and it is retrieved correctly in the mailTo function.
PHP 8.2.24
Typo3 v12.4.23 LTS
Aimeos web shop 24.10.2
Re: BCC-Mail is not sent
Post by aimeos » 04 Dec 2022, 10:22
Since TYPO3 v10, this is a never ending source of problems:
https://github.com/aimeos/aimeos-typo3/issues/164
Moritz
Post by Moritz » 06 Dec 2022, 10:22
So the two workarounds are:
  • Use -bs in the sendmail command
    /usr/sbin/sendmail -bs
  • Using the new Email delivery service provider to send order e-mails to shop owners
I can't test the first point currently because sendmail is not working on our server.
But in my test environment I use smpt with my mail to send emails.
There is bcc also ignored.
Can you explain how to implement the second point please?
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 07 Dec 2022, 09:21
The Email service decorator is documented here:
https://aimeos.org/docs/latest/manual/services/#email
Moritz
Post by Moritz » 08 Dec 2022, 15:48
So then I have to configure it for every delivery service to have a workaround for the bcc problem?
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 09 Dec 2022, 14:38
Yes
Moritz
Post by Moritz » 15 Dec 2022, 15:45
Moritz wrote: 06 Dec 2022, 10:22 So the two workarounds are:
Unfortunately, the first option does not work for me.
When I use the Email delivery service provider. Can I disable the attachment (order.csv)?
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 19 Dec 2022, 08:35
You have to create your own delivery service provider and overwrite the send() method to remove the attachment:
https://github.com/aimeos/aimeos-core/b ... #L156-L170
Moritz
Post by Moritz » 16 Jan 2023, 12:30
How can I use translation in my own delivery service provider?
When I use the following function it ignores my translations in TSConfig field of the task.
$this->context()->translate('client/code', 'download');
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 18 Jan 2023, 10:18
Can you post your TSConfig content?
