Omnipay Authorize.net AIM checkout error
siddharthamahata
Post by siddharthamahata » 02 Oct 2015, 15:23
After applying Omnipay Authorize.net AIM seetings in the admin panel (settings image below) , I get this error while checkout.
Admin authorize.net settings -
I can't seem to figure out what is this number parameter.
I get this same error with Omnipay paypal_pro too.
However Omnipay 2checkout redirections work fine.
Can anyone please help , as to where is the mistake I am doing?
Re: Omnipay Authorize.net AIM checkout error
Post by aimeos » 03 Oct 2015, 10:03
siddharthamahata wrote: I can't seem to figure out what is this number parameter.
Some payment provider need special handling and won't work with the standard Omnipay provider. For Authorize.net AIM, you have to use the AuthorizeAIM provider:
https://aimeos.org/docs/User_Manual/Adm ... ze.net_AIM
PayPal Pro might be the same case. You can use the Aimeos PayPal provider instead:
https://aimeos.org/docs/User_Manual/Adm ... PalExpress
It would be great if you what kind of configuration is requred for those payment providers that are not yet listed :-)
https://aimeos.org/docs/User_Manual/Adm ... i-payments
