Bootstrap is not compatible with PopperJS v2
TGergo
Post by TGergo » 07 Dec 2022, 11:46
php version 8.1
Windows 10
Aimeos version 2022.10.2.
Hello!
I would like to user Bootstrap popover component, but Popperjs v2 is not compatible with Bootstrap v5.1.3
And Popper doesn't support multiple popover, but Bootstrap popover support that.
Can You help me?
Re: Bootstrap is not compatible with PopperJS v2
Post by aimeos » 08 Dec 2022, 10:42
The latest aimeos/ai-client-html 2022.10.x package includes Bootstrap 5.2.x and PopperJS 2.0:
https://github.com/aimeos/ai-client-htm ... js#L44-L52
TGergo
Post by TGergo » 12 Dec 2022, 13:20
Thx, I tried. I read on other sites, Bootstrap 5.x.x. only compatible with PopperJS v1
Post by aimeos » 12 Dec 2022, 13:35
That's not true for Bootstrap 5.2 any more which uses popperjs/core v2.10.2 as you can see here:
TGergo
Post by TGergo » 19 Dec 2022, 13:07
Yes it works now.
app.js contained a smaller size bootstrap code, not all of it.
Post by aimeos » 20 Dec 2022, 15:46
Yes, the Bootstrap code is optimized and only contains the necessary code for the "default" theme.
