The filter sometimes disappears
TGergo
Post by TGergo » 08 Dec 2022, 14:02
php version 8.1
Windows 10
Aimeos version 2022.10.2.
Hello!
The filter sometimes disappears. (it doesn't appear when I click on it)
The javascript works well.
<div class="attribute-lists" style="display: block;">
But it doesn't appear.
Sometimes works well, I don't know why. I have no javascript console error.
HTML included filter data.
I think, <fieldset class="attr-sets" keeps display: none;
/* Enabled by JS */
.catalog-filter-attribute .attribute-lists fieldset.attr-sets,
.catalog-filter-attribute .attribute-lists fieldset.attr-sets .attr-list {
display: none;
Re: The filter sometimes disappears
Post by aimeos » 09 Dec 2022, 14:38
The fieldsets for the attribute types are automatically hidden if there are no products matching one of their attributes.
TGergo
Post by TGergo » 12 Dec 2022, 13:15
I understand, but I have products for filter.
I can read in the HTML code.
For example: Years
But the Filter sometimes show, sometimes keep display:none.
Other thing I don't understand
I have product from year 1971.
But it's not in the filter, gives a result when I click on it.
I ran it:
php artisan aimeos:clear;
php artisan cache:clear;
Post by aimeos » 13 Dec 2022, 08:35
Do you have a lot of products (> 10,000)?
In that case, there's a (configurable) limit of how much products are counted for the filter.
TGergo
Post by TGergo » 13 Dec 2022, 10:46
I have 8000 records.
TGergo
Post by TGergo » 13 Dec 2022, 12:19
For the first problem.
in the catalog-filter.js #213
* Shows the attribute filter if products are available for
onShowAttributes() {
// sometimes empty
console.log($(".catalog-filter-attribute .attribute-lists .attr-count"));
$(".catalog-filter-attribute .attribute-lists .attr-count").each((idx, el) => {
$(el).closest("fieldset.attr-sets").show();
Post by aimeos » 14 Dec 2022, 08:59
Try to increase the aggregation limit e.g. to 25000:
https://aimeos.org/docs/2022.x/config/m ... ger/#limit
TGergo
Post by TGergo » 14 Dec 2022, 09:58
aimeos wrote: 14 Dec 2022, 08:59 Try to increase the aggregation limit e.g. to 25000:
Thank You, It works fine at 50000.
Post by aimeos » 14 Dec 2022, 10:02
Please take in mind that counting that many rows will slow down response time!
