csv product import
csv product import
We've been trying to import products via csv file and when executing the crontab, it logs that the cron started and finished, but nothing is imported. Is it an issue with our csv or our settings, or something of sorts? (file path tried with both just the directory and pointer to the file)
Tried the example file found on your docs and our own.
typo3 11.5.10
php 8.12
aimeos 22.10.3
exempt from our csv file:
typo3 11.5.10
php 8.12
aimeos 22.10.3
"JF0040044","Notizblock mit ESWE Logo DIN A5","default","1",,,"long","Notizblock im Format A5 mit ESWE Logo, kariert.Preis pro Stück","media/notizblock-a5-kariert-mit-logo.png","EUR","1","1.22","7.00",,,,"default",,,,,
"JF0001205","Radiergummi Doppel-Läufer","default","1",,,"long","Die rote Seite radiert Blei-, Farb-, und Kopierstifte, die blaue Seite radiert Tinte, Tusche und Toner. Doppelseitig, mittelweich.Material: Naturkautschuk .Maße: 55 x 19 x 8,5 mmPreis pro Stück","media/radiergummi-doppel-laufer-3.jpeg","EUR","1","0.34","7.00",,,,"default",,,,,
"""JF0001750"",""Additionsrollen (Verkauf einzel)"",""default"",""1"",,,""long"",""Für Tischrechner, elementarchlorfrei (ECF), holzfrei, mit End-Warnstreifen. Grammatur: 60 g/qm.
Preis pro Stück"",""media/additionsrollen-5.jpeg"",""EUR"",""1"",""1.01"",""7.00"",,,,""default"",,,,,"
"JF0001680","Enthefter","default","1",,,"long","Stabile Metallausführung mit rutschfesten Kunststoffgriffen. Löst alle Heftklammern (24/6, Nr. 10) und Reißnägel.Preis pro Stück","media/enthefter.png","EUR","1","0.97","7.00",,,,"default",,,,,
- Screenshot 2022-12-13 153828.png (7.85 KiB) Viewed 20242 times
Re: csv product import
The TypoScript configuration isn't valid and must be:
See: https://aimeos.org/docs/latest/typo3/cu ... figuration
controller.jobs.product.import.csv.location = /var/...
controller.jobs.product.import.csv.skip-lines = 1
Unfortunately, exchanging the slashes with dots did not result in the cronjob importing. It still continues to say that it started and finished.
Dec 14 11:20:34 webserver3-sandbox systemd[1]: Starting Checkmk agent (10.23.12.141:48796)...
Dec 14 11:20:36 webserver3-sandbox systemd[1]: check-mk-agent@16558-192.168.111.41:6556-10.23.12.141:48796.service: Deactivated successfully.
Dec 14 11:20:36 webserver3-sandbox systemd[1]: Finished Checkmk agent (10.23.12.141:48796).
Dec 14 11:21:01 webserver3-sandbox CRON[3724453]: (root) CMD (/root/shopcronscript.sh > /dev/null 2>&1)Re: csv product import
Your log output contains no hints of the importer.
If it starts and ends without further notice, usually no file to import was found.
Hi there,
happy new years!
We figured the cron out and all, but now when running the cron it fails, leaving us with this stacktrace:
https://pastebin.com/56dt9ze6
the test file content: https://pastebin.com/sjnjEwi7
happy new years!
Your test file is wrong because each field is enclosed by """ instead of "
hey there,
removed the """ from non-integer fields.
now looking like
throws this now.
it never finishes though, and as such nothing is imported.
now looking like
"JF0001205","Radiergummi Doppel-Läufer","default",1,,,"long","Die rote Seite radiert Blei-, Farb-, und Kopierstifte, die blaue Seite radiert Tinte, Tusche und Toner. Doppelseitig, mittelweich.Material: Naturkautschuk .Maße: 55 x 19 x 8,5 mmPreis pro Stück","media/radiergummi-doppel-laufer-3.jpeg","EUR",1,0.34,7.00,,,,"default",,,,,\n
Started product import from "/var/www/xyz/fileadmin/user_upload/Import" (Aimeos\Controller\Jobs\Product\Import\Csv\Standard)Re: csv product import
Is the "\n" at the end of the line really a new line or just a backslash and the character "n"?
In this case its a new line.
But we've tried it with /n and without. It doesn't affect the outcome.
I also get this error:
503 Oops, an error occurred!
Call to undefined function Aimeos\Controller\Common\Product\Import\Csv\Processor\Text\mb_strcut()
