want to list child categories
mahammadareef
Post by mahammadareef » 15 Dec 2022, 10:00
I wanted to show the next child categories lists of parent categories in the catalog List page when the parent category is active in catalog List page .............
please explain to me with steps to fulfill this ...
for checking, I am uploading an image ...
Thanks in advance ...
Screenshot 2022-12-15 152246.jpg (172.51 KiB) Viewed 9857 times
Re: want to list child categories
Post by aimeos » 19 Dec 2022, 08:24
You can use code similar to this one.
The first is a decorator for the catalog list component you have to place in ./src/Client/Html/Common/Decorator/ directory:
<?php
namespace Aimeos\Client\Html\Common\Decorator;
class ListCategories
	extends \Aimeos\Client\Html\Common\Decorator\Base
	implements \Aimeos\Client\Html\Common\Decorator\Iface
	public function addData( \Aimeos\Base\View\Iface $view, array &$tags = array(), string &$expire = null ) : \Aimeos\Base\View\Iface
		$view = parent::addData( $view, $tags, $expire );
		$view->listNode = \Aimeos\Controller\Frontend::create( $this->context(), 'catalog' )
			->uses( ['media', 'text'] )->root( $view->param( 'f_catid' ) )
			->getTree( \Aimeos\Controller\Frontend\Catalog\Iface::LIST );
		return $view;
Then, you have to configure the decorator in the ./config/client.php file of your extension:
    'html' => [
        'catalog' => [
            'lists' => [
                'decorators' => [
                    'global' => ['ListCategories']
Finally, render the categories in the catalog/list/body.php template.
<?php if( isset( $this->listNode ) ) : ?>
        <?php foreach( $this->listNode->getChildren() as $item ) : ?>
                <a class="cat-item" href="<?= $enc->attr( $this->url( ( $item->getTarget() ?: $target ), $controller, $action, $params, [], $config ) ); ?>">
                        <?php if( $mediaItem = $item->getRefItems( 'media', 'default', 'default' )->first() ) : ?>
                                <img src="<?= $enc->attr( $mediaItem->getPreview() ) ?>" >
                        <?php endif ?>
                        <span class="cat-name"><?= $enc->html( $item->getName(), $enc::TRUST ); ?></span>
                </a>
        <?php endforeach; ?>
<?php endif ?>
PedroLópezAndradas
Post by PedroLópezAndradas » 25 Jan 2023, 11:00
Thank you for your help and support in this forum :)
I'm trying to get same functionallity,but in common/partials/products.php
Where do I have to register my decorator?
	'html' => [
		'common' => [
			'partials' => [
				'decorators' => [
PedroLópezAndradas
Post by PedroLópezAndradas » 26 Jan 2023, 12:46
I have tried to replicate this example in catalog/lists, and I'm unable to achieve it.
It is like if the decorator is not being used. Do we need to register somewhere else than in client.php config file on our extension?
<?php
return [
	'html' => [
		'themes' => [
			'xxxx' => 'xxxx',
		'theme-presets' => [
			'xxxx' => [
				'--ai-product-image-ratio' => '3/4',
				'--ai-bg' => '#FFFFFF',
				'--ai-bg-alt' => '#F6F6F6',
				'--ai-primary' => '#FFF000',
				'--ai-primary-alt' => '#282828',
				'--ai-secondary' => '#555555',
				'--ai-secondary-alt' => '#555555',
				'--ai-tertiary' => '#CCCCCC',
				'--ai-tertiary-alt' => '#F6F6F6',
				'--ai-danger' => '#A00000',
				'--ai-success' => '#006000',
				'--ai-warning' => '#FFA500',
				'--ai-radius' => '0',
		'catalog' => [
            		'lists' => [
                		'decorators' => [
	'jsonapi' => [
Post by aimeos » 26 Jan 2023, 13:26
You still have to register the decorator for the catalog/lists component but you want to use the data in a partial so you have to pass the new data to the partial too:
https://github.com/aimeos/ai-client-htm ... #L148-L157
PedroLópezAndradas
Post by PedroLópezAndradas » 30 Jan 2023, 08:34
Yes, but I'm having problems getting params from the view in the first example, directly in templates/client/html/catalog/lists/body.
My decorator:
<?php
		$view->set('test', 'hello');
		return $view;
	public function getCat(){
		return 'ey!';
My config:
<?php
return [
	'html' => [
       	 	'catalog' => [
            		'lists' => [
                		'decorators' => [
                    			'global' => ['ListCategories'],
	'jsonapi' => [
My template client/html/catalog/lists/body.php:
		<?php
			//Testing decorator
			var_dump( $this->get( 'test' ) ); 	//Returns NULL
			var_dump( $this->getCat() ); 	//Returns ERROR
I think I'm missing something important, because it is like if decorator is not being detected.
Post by aimeos » 31 Jan 2023, 09:13
The example code for ListCategories is for Aimeos 2021.x, in 2022.x the method has been renamed from "addData()" to "data()" only.
PedroLópezAndradas
Post by PedroLópezAndradas » 31 Jan 2023, 09:26
Yes! It works!
Thank you!
Now I have an error taking the url of the children categories, but I'll be able to figure out why.
Thanks!
