Aimeos Laravel events
PraveenJayakody
Post by PraveenJayakody » 23 Dec 2022, 01:35
I'm on Laravel 9, Aimeos 2022.x and PHP 8.1 on Mac.
I want to send an SMS to the user (i.e. call a third party API) when an order is created. What is the standard way to accomplish this? Does Aimeos propagates Laravel Events that can be listened to? At this point, I should also be able to get at least the order baseId or customer details like the phone number
TIA
VirtualSpy
Re: Aimeos Laravel events
Post by VirtualSpy » 23 Dec 2022, 09:21
PraveenJayakody wrote: 23 Dec 2022, 01:35 Hi,
TIA
do config for mandatory fields of billing and delivery address and add there telephone field and then do config for translation for showing telephone to mobile no. or phone no...it stores in laravel's user table which is merge from customer table of aimeos and you will get order id from order tables of aimeos. ..... it will helpful for you for sending sms and for third party api wait for reply from aimeos
Post by aimeos » 23 Dec 2022, 14:56
The best option would be to create a delivery service decorator, which sends the SMS to the customer when the order/service/delivery job controller executes the processBatch() method:
https://aimeos.org/docs/latest/provider ... ecorators/
