Adapt themes
Adapt themes
Hi!
I want to overwrite default shop theme by updating: "public/vendor/shop/themes/default/aimeos.css" file. But site prefers styles from the screenshot. How can I force site to use "public/vendor/shop/themes/default/aimeos.css" file styles?
Laravel 9.19.
PHP 8.0.2
Laravel 9.19.
PHP 8.0.2
- 23.png (51.38 KiB) Viewed 3050 times
Re: Adapt themes
The custom CSS variables are stored in the mshop_locale_site.config column, so you can remove them from there. Alternatively, you can remove adding the custom CSS for the base Blade file here (in your own copy):
https://github.com/aimeos/aimeos-larave ... hp#L22-L28
Re: Adapt themes
Thanks, it works!aimeos wrote: 28 Dec 2022, 20:59 The custom CSS variables are stored in the mshop_locale_site.config column, so you can remove them from there. Alternatively, you can remove adding the custom CSS for the base Blade file here (in your own copy):
