want to add owl slider
mahammadareef
Post by mahammadareef » 28 Dec 2022, 06:11
i want to use the owl slider in aimeos but it works on jquery ,,, how i can add and use it in my aimeos application without affecting the existing code ....
Re: want to add owl slider
Post by aimeos » 28 Dec 2022, 21:11
It's recommended to use the already available SwiffySlider instead because
- It's much faster and offers much better Lighthouse results
- It doesn't depend on jQuery which has been removed in Aimeos (cash-dom is used as modern replacement again)
If you want to use the OWL slider nevertheless, you should create a new Aimeos theme and add jQuery and OWL code while removing cash-dom.
mahammadareef
Post by mahammadareef » 29 Dec 2022, 09:22
I would like to know
1. file path of the cash-dom library in aimeos
2. if I remove the cash-dom library and replace it with jquery is my existing javascript file will work fine ......example: account-favorite.js
3. the steps to replace aimeos cash-dom and replace it with jquery in the easiest and safe way
Post by aimeos » 30 Dec 2022, 19:16
This is the cash-dom code:
https://github.com/aimeos/ai-client-htm ... .js#L1-L42
The rest of the code should work if your replace it with jQuery again in a new theme.
