Jsonapi for save basket empty problem
skydev
Post by skydev » 05 Jan 2023, 06:33
We need help with JSON API.
In JSON API basket save always gives a "Basket is empty" response.
is this any solution for API calls?
We have used csrf token as well. It works when we call in a saved basket from the postman.
As we check below basket check function not working or it might become an empty basket before saving the basket and after adding to the cart.
$this->controller->setType( $view->param( 'id', 'default' ) );
$this->controller->get()->check();
$this->clearCache();
$item = $this->controller->store();
$this->context()->session()->set( 'aimeos/order.baseid', $item->getId() );
$view->item = $item;
$status = 200;
Composer code for version which we use currently.
"aimeos/aimeos-laravel": "~2022.07",
"guzzlehttp/guzzle": "^7.2",
"laravel/breeze": "^1.9",
"laravel/framework": "^9.2",
"laravel/sanctum": "^2.14.1",
"laravel/tinker": "^2.7"
Thanks in Advance!
Re: Jsonapi for save basket empty problem
Post by aimeos » 05 Jan 2023, 08:10
Can you please update to 2022.10 LTS as 2022.07 isn't supported any more.
Do you use file based or database based Laravel sessions?
Do you have example code to reproduce the issue?
