JsonAPI: call to OPTIONS needed every single time?
rowild
Post by rowild » 10 Jan 2023, 15:45
I am confused: The JSONAPI documentation and its jquery code examples imply that on each and every call to a resource, OPTIONS must first be called. Is my assumption correct or false?
If I was to create a Vue or React app, I would use axios on initial call and save the resources to a local variable or a pinia variable. That way the OPTIONS request only has to be executed once. Am I totally wrong with that?
Also, the jquery examples seem a bit out of date. Are there any plans to update them? Maybe axios examples?
Re: JsonAPI: call to OPTIONS needed every single time?
Post by aimeos » 12 Jan 2023, 09:46
In a PWA built with VueJS or ReactJS, you need to call the OPTIONS URL only once. The resources doesn't change.
rowild
Post by rowild » 13 Jan 2023, 10:54
Thanks for clarifying that for me! Much appreciated! :-)
