How to create or modify header menu?
PedroLópezAndradas
Post by PedroLópezAndradas » 16 Jan 2023, 11:51
I have seen that the header menu can be changed by editing Catalog->Categories.
But I would like to know if we can edit the menu to add a custom link to a page, or the entire product store, instead of just a category. Is there any way to do this from the admin panel?
If not, what would be the steps to overwrite or extend the current category menu? I have not found these explanations in the documentation.
Thanks for your help!
Re: How to create or modify header menu?
Post by aimeos » 17 Jan 2023, 10:35
The catalog filter tree part only displays categories from the Aimeos backend. If you want to add other links in the header, you have to add them to the navigation header in the base.blade.php file:
https://github.com/aimeos/aimeos-larave ... hp#L37-L70
Copy the file to your ./resources/views/vendor/shop/ directory and adapt it to your needs:
https://aimeos.org/docs/latest/laravel/ ... -templates
