How to access css variables in custom theme
PedroLópezAndradas
Post by PedroLópezAndradas » 17 Jan 2023, 13:03
I have created a new theme through an extension.
I see the css variables hardcoded in 'aimeos.css', but I would like to use the custom ones in the admin panel.
How can I get and use those values?
Thanks!
Re: How to access css variables in custom theme
Post by aimeos » 18 Jan 2023, 10:24
The available CSS variables can be configured in the ./config/client.php file of your theme extension like in the ai-client-html extension: https://github.com/aimeos/ai-client-htm ... #L285-L301
There, you can tell the Aimeos backend, which variables are available and what their default values are. Then, the variables are injected into the page where you have access to them in your CSS:
https://github.com/aimeos/aimeos-larave ... hp#L22-L28
PedroLópezAndradas
Post by PedroLópezAndradas » 18 Jan 2023, 11:06
Thank you so much!
I was moving around the solution without finding it. :D
