Search Button Hidden in Mobile Page Widths
briajer
Post by briajer » 20 Jan 2023, 11:34
I would like to keep the Search Button visible when the view changes due to responsiveness.
The Locale Options stayed visible but the search icon disappears.
I removed the code for "@yield('aimeos_head_locale')" in the base.blade.php to make room for the Search Icon.
I have also tried moving the search Icon next to @yield('aimeos_head_basket'), which works in desktop view but still disappears in mobile view.
Where can I change this behaviour? I'm guessing it's CSS in the Default Navbar / theme but i'm not sure where to look.
Re: Search Button Hidden in Mobile Page Widths
Post by aimeos » 25 Jan 2023, 11:45
briajer
Post by briajer » 25 Jan 2023, 20:07
From html inspection - button.btn.btn-search / section.aimeos.catalog-filter seems to be what I would like to stay visible.
In mobile view the search button inside the Navbar disapears in mobile view but the account and basket buttons stay visible
I also tried playing with the @yield('aimeos_head_search) (base.blade.php)
I can't find the specific CSS to affect the class in the input-group / flex (div.search-lists)
If you know specifically where this CSS is it would be helpful Thanks
Post by aimeos » 27 Jan 2023, 09:38
Take a closer look at the absolute positioning here:
https://github.com/aimeos/ai-client-htm ... #L399-L406
